AcyMailing is built to be as flexible as possible. That’s why we worked on several integrations with Joomla extension to ease your newsletter creation or your email marketing campaigns.
AcyMailing Joomla's Integration
- Insert CB user fields in your emails
- Filter your users based on CB fields
- Insert surveys in your emails
- Insert documents in your emails
- Insert events in your emails
- Filter your users based on their event registrations
- Trigger automations based on starting events
- Filter users based on their event subscriptions
- Insert EasyBlog content in your emails
- Insert FLEXIcontent articles in your emails
- Insert Seblod articles in your emails
- Insert User information in your emails from the Easyprofile extension
- Insert products and generate coupons in your emails
- Filter your users based on their purchases
- Trigger automations when an order gets confirmed
- Insert K2 items in your emails
- Insert products in your emails
- Create and send personal coupons to your receivers
- Filter your users based on their VM fields
- Filter users based on their shopper groups
- Filter customers based on their purchases
- Insert User information in your emails from the EasySocial extension.
- Filter users on their profile type
- Filter users on their EasySocial group
- Filter users on their badges/achievements
- Filter users on their EasySocial fields
- Filter users attending events
- Filter your users based on their subscription plans
- Insert file descriptions in your emails
AcyMailing Joomla's Add On
If you want some new features. You are in the right place! Check our AcyMailing Add On to personalize and to boost your AcyMailing experience on Joomla.
Features :
- Add an action in the automation to export your users
- Export every data of your users
- Choose the encoding
- Choose the path and the name of the file where you export your users
This email checker allows you to improve the deliverability of your emails, to reduce your costs or to keep a good reputation by using its WordPress (or Joomla) plugin or its API.
This email checker allows the verification of emails at different levels:
- Domain and SMTP check
- Role email checker
- Disposable email checker
- Free provider
- Email format checker
- In-depth tests
Features :
- Add a new droppable button on the editor to generate a table of contents in your email
- Select which elements of your emails should be listed (h1, h2, etc)
- Choose between two displays
Features :
- Insert content in your emails from an RSS link
Features :
- A simple filter in the automations with the possibility to select the table and columns needed
- An advanced filter in the automations with the possibility to enter an entire sql query to match some users anywhere in your database
- A filter able to extract addresses from a text
- Import users in automations and filter them for the actions
