AcyMailing is built to be as flexible as possible. That’s why we worked on several integrations with WordPress plugin to ease your newsletter creation or your email marketing campaigns.
AcyMailing WordPress Integration
Execute action when a user buys a product.
Track your incomes from a campaign.
Features :
- Add a new droppable button on the editor to add products from WooCommerce to your email
- Display products in the email
- Select the data you want to display (pictures, title, link etc)
- Customize the html render in the plugin settings
- Filter users based on products they have bought
- Execute actions when a user buys a product
- Track your incomes per campaign
Features :
- Add a new button on forms edition to add AcyMailing lists
- Display AcyMailing lists in the forms
- Create AcyMailing users and subscribe them to the lists they selected
Filter users on events participation.
Features :
- Add a new droppable button on the editor to add events from The Events Calendar to your email
- Display events in the email
- Filter users on events participation
Features :
- Add a new droppable button on forms edition to add AcyMailing lists
Features :
- Add a new droppable button on the editor to add events from Modern Events Calendar to your email
Features :
- Add a new droppable button on the editor to add events from Events Manager to your email
Features :
- Add a new droppable button on the editor to add events from EventOn to your email
- Add a new trigger in the automation when a user subscribe to a new membership
- Filter your users on their member subscription
- Add users custom field value to your emails
REQUIREMENTS
AcyMailing
Ultimate Member
Add AcyMailing lists to your Ultimate Member forms
Features :
- Add a new section in the AcyMailing configuration to add lists to your forms
Create individual coupon codes for your receivers.
Features :
- Add a new droppable button on the editor to add products to your emails
- Automatically create individual coupon codes for each receiver
AcyMailing WordPress Add On
If you want some new features. You are in the right place! Check our AcyMailing Add On to personalize and to boost your AcyMailing experience.
Features :
- Add an action in the automation to export your users
- Export every data of your users
- Choose the encoding
- Choose the path and the name of the file where you export your users
This email checker allows you to improve the deliverability of your emails, to reduce your costs or to keep a good reputation by using its WordPress (or Joomla) plugin or its API.
This email checker allows the verification of emails at different levels:
- Domain and SMTP check
- Role email checker
- Disposable email checker
- Free provider
- Email format checker
- In-depth tests
Features :
- Add a new droppable button on the editor to generate a table of contents in your email
- Select which elements of your emails should be listed (h1, h2, etc)
- Choose between two displays
Features :
-Add RSS feed to your emails via the AcyMailing drag and drop editor
Features :
- Add a new droppable button on the editor to add RSS feed to your email
- Display all article in the email
Features :
- A simple filter in the automations with the possibility to select the table and columns needed
- An advanced filter in the automations with the possibility to enter an entire sql query to match some users anywhere in your database
- A filter able to extract addresses from a text
- Import users in automations and filter them for the actions
